It is currently Mon Aug 11, 2025 5:04 pm
 Post subject: what binding tape?
PostPosted: Tue Dec 15, 2009 9:09 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
Whats the best binding tape you all have found that can be purchased from Home depot, Lowes,,etc... I like the LMI tape but run out. What comparable to that??
 Post subject: Re: what binding tape?
PostPosted: Tue Dec 15, 2009 9:25 pm
If your binding is preformed, and is a very good fit, you can use the basic 3M blue painters tape (regular kind) and just double up on it. I've done several guitars that way and it has worked like a dream.
PostPosted: Tue Dec 15, 2009 9:32 pm
Lots of ways to do this. I use a method recommended by some folks that are much more experienced than I. I use 3M green masking tape (3M 233+) that has some stretch to it. Alternate as you put it on: top to the side on one, then side to the top on the other. Doesn't need to be doubled up. Usually on the shelf at automotive paint supply stores. Of course the binding still needs to fit well.
PostPosted: Wed Dec 16, 2009 12:37 am
Lots of tape will work. I like the Stew Mac tape for routine stuff and the fiberglass reinforced tape to really pull the binding in tight at places like the waist and cut-away.
PostPosted: Wed Dec 16, 2009 8:15 am
I use duct tape...works really well.
PostPosted: Wed Dec 16, 2009 2:23 pm
I am going to second 3M Strapping tape. It does not react with CA like the adhesive on masking type and SM's binding tape. Holds well and comes off easy with less fiber tear out the SM's
PostPosted: Wed Dec 16, 2009 3:26 pm
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
The medium strength blue tape works great, though I haven't had a chance to try the green yet. The low-tac blue isn't going to work too well...avoid it unless you are just masking for finish or paint.
I wonder about packing and/or duct tape leaving residue/sticky behind...how well do they do with that? Obviously, Gorilla tape is WAY out. laughing6-hehe
-Matthew
PostPosted: Fri Dec 18, 2009 1:50 pm
Scotch 233+. I've used StewMac brown tape, strapping tapes from various makers, blue masking, white masking, etc. You get more pressure from the 233+ because of its elasticity. The local hardware store won't have it, but you can order from Amazon.
PostPosted: Fri Dec 18, 2009 4:12 pm
Scotch 233 AKA green tape. You can find it at local "car" stores like CarQuest and others in 3/4" and 1/4" width. Like Howard pointed out, it's elastic yet most resilient under pressure. The 1/4" is handy for tight waists and cutaways.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Dec 18, 2009 6:15 pm
I get my tape from Uline. it is available in larger quantities and thus less expensive . I use stretch tape
PostPosted: Fri Dec 18, 2009 6:41 pm
I'm in the 233 camp. I get mine at NAPA auto stores. I think for less then the blue painters tape.
PostPosted: Fri Dec 18, 2009 9:36 pm
First name: Jim Howell
Yet another vote for the green tape. [:Y:]
Jim Howell
Charlotte, NC
PostPosted: Sat Dec 19, 2009 11:20 am
233 here as well. Good stuff.
Users browsing this forum: wbergman and 27 guests
